Is it possible to use ModelCheck to see if a drawing has a particular table? I've tried using the TABLE_CELLS and DRW_TABLE_CELLS but this check seems very limited and only activates if the table exists in the first place.
@lwestbrook Should it add this idea to Changes to allow ModelCheck to be more Flexible/Useful or create a new Product Idea?
Hi Luke,
Can you add it to a separate Product Idea? Having individualized ideas helps with prioritization and general communication.
Thanks!
Luke Westbrook
