I am trying to enable ModelCheck Gatekeeper to prevent check-in of models if they do not contain proper parameters and values.
When I do a check-in, I get the following error messages:
Incorrect ModelCHECK mode used on models in the context
Incorrect set of config files used on ModelCHECK in the context
Model has not been validated in last 24 hours in the context
ModelCHECK failed on models in the context
Running ModelCHECK interactively, I get no errors or warnings.
Creo7.0.5.0 with Windchill 11.1 M020 CPS20
There some configuration required in both Creo ModelCheck setup and Windchill preferences - Windchill Help - Managing ModelCHECK Validation during Check In
Here's some additional info:
Setting ModelCHECK Mode to disabled and ModelCHECK Configuration to blank did the trick.
If the parameter I want to enforce is not set, it triggers an error and the check-in fails.
Setting for material still passed and allowed the check-in, but I will work on that. It is secondary to the one that is required.
