I am new in the world of modelcheck. I have read a bunch of articles about this theme on the creo support website, but still dont really know how to start this whole from the begining.
Firstly i have set my config.pro option yes for MC, and given a location for my MC optionfolder. Afterthat I have enabled MC at MC_ENABLED option, but still when I am trying to make an MC Interactive it sais that MC is disabled.
Thanks.
Levente
I highly recommend this book:
Which version of Creo you are working with?
Make sure you installed Creo ModelCHECK with Creo Parametric. It is available under Customize > Application Features > Check "Creo ModelCHECK.
Also, you have to check whether the license contains ModelCHECK module.
Firstly thanks for the reply.
I am working with creo 7, and i have also checked that my license contains modelcheck.
please attach picture showing how did you check the presence of Modelcheck license.
Set config options as:
Environment Variable (System Variable):
Also, note that Creo will consider the directory mentioned in an environment variable.
