Vaughn,
I understand your concern about family tables (method 1), but I think that is the best approach. When using the part in an assembly, I find it to be easier to replace the component if it is a member of a family table. However, I was wondering if it is possible to assign a different material to each family table member.
I probably wound not use assemblies (method 4), but method 3 could be a good approach provided you have the AAX module (may Pro-E users do not). I know some Pro-E users without the AAX module use stand alone parts (method 2), and I likewise wonder if there is a better alternative. Post a summary of what you find out.
Chris
In Reply to Vaughn McDaniel:
Like many of you we create items/part numbers (PN) with the same geometry but in a different color/material. What we would like is
I think there are four ways to do this.
1. Family Table
2. Stand-Alone parts
3. Inheritance/Merge/CopyGeom (Same relationship structure)
4. Assemblies
Family Tables, used in the past, are out because of our regimented change control process.
Stand-alone parts are no fun, having to change multiple models for the same geometry change, and which one gets sent to the toolmaker?
Maybe having a general/master .prt and then add that into an assembly to make the PN, this takes care of mass geometry changes, and clears up which one drive the tooling, but now there is a part model that gets no PN, thus could be out of control and assemblies where they are not needed.
Inheritance/Merge/CopyGeom seems good, no assembly structure, mass geom. update is easy. It is an advanced feature, so could confuse some users.
In your experience what are the downfalls of any of these methods? Which do you use? I'm just looking for that burn that I don't see.
Thanks for your comments.
WF3.0, soon to be 5.0
Ilink 3.x soon to be Windchill 9.1
Vaughn McDaniel III | CAD/PLM Administrator | Kärcher NA - Englewood |303-762-1800x187 |vaughn.mcdaniel@karcherNA.com<
Please note my new email address.
[cid:image001.jpg@01CA945F.1B7AD840]
Hi Vaughn,
I think we've probably had this conversation at PTC User, but since I've been harping on this topic for a couple years now, I'll add my 2 cents.
We attempt to avoid creating the same part multiple times in Pro/E because it is not value-added work for the engineers/designers. We use a variable in our ERP part number to indicate color/finish that does not affect the functional design of the component. (Due tocorporate changes, we still do not have EPM Documents in Windchill).
With Windchill being the master repository of our BOM's, we will be forced to either create 1:1 Pro/E files for colors/finishes, or have disassociated BOM part structures in Windchill, negating the benefit of part and cad document association.
I believe we will most likely use inheritance features to create these multiple parts/drawings. We have discouraged our users from family tables for years due to the overhead of and historical 'flakiness".
Joshua Houser
MCAD Tools Administrator
Pelco
Worldwide Headquarters:
3500 Pelco Way
Clovis, CA 93612-5699 USA
Phone 559/292-1981
North America 800/289-9100
www.pelco.com
Since we have AAX I'm trying to go down the Inheritance route, seems like the right tool for the job.
Those of you who use inheritance:
My next hurdle is: We don't 'always' know what the requirement for a part will be in the future. We could release version 1-green and 2 years later version 2-blue comes along. So should we:
1. Use aparent driving model, such as tank_geometry.prt and that will drive 1-green.prt and 2-blue.prt
OR
2. Use 1-green.prt as the parent for 2-blue, 3-yellow
I wantONE rule that applies to all myscenerios. #1 seems excessive to do for every inj molded, painted part, just incase we make a different color'some' day.
I think I'm fine with #2, our PN are incrementing and PLM knows the trail back to the intial one.
A couple more options are:
5 - Multi part drawings, represent the different colors on atable on a single drawing.
6- General drawing and seperate specification document for different colors.
We have always modelled every part. Makes sense when you are trying to drive the BOM for the CAD, you need to represent it some how.
SUMMARY:
We are going to go down the Inheritance road,we have not heard of one disadvantage. Our two largest concerns are -Replacing in an assembly and creating the drawing.
We are up in the air about the drawing we will use, create new, or an overlay.
Inheritance models can be <u>automatically replaced in assmblies</u> as easy as Family Tables: From Pro/E Help:
Other responses:
Hi Vaughn,Rodney Decker
Engineer
Leggett & Platt Storage Products Group
We create the raw assembly and an associated drawing. Then create the painted assemblies with the first item being the unpainted assembly.Ron
Maybe I am wrong but is there not a 5th way?
We have a lot of identical parts with different materials (& of course different part#s). We just put a chart on the drawing with a column for the part#s, material, color, spec#s, markings, etc...
One model, one drawing, charted. Very simple & it works very well for us.
Joe S.
For what it’s worth I family table a lot. We have hot rolled and galvanized equipment that have identical geometry, so I have a generic and as many instances as I need, then I create (when it makes the most sense) a drawing table that’s automatically filled in by the family table. I just find it a time saver for that as well as the ease of using the replace feature in assemblies.One more issue on this:
Family Tables allow you to switch instances in a drawing and not have to start over just for a color change. Does merge have a way to do this?
