Modifica file .TBL
RP_8326409
2-Explorer
Modifica file .TBL
Good evening.
I am using Creo Parametric - Release 3.0 (connected) Release 3.0 and DatecodeM150
I'm asking for support to understand how to modify a table in order to allow the correct interfacing with the parameters of a 3D model. See attached file for more information.
I don't know the string identifying the Connected System (Connected System field of the Request), so I have filled it in at random.
Translated with deepl.com
Translated by Corina Ionescu on Feb 23rd 2022
Buonasera.
Chiedo supporto per capire come modificare una tabella in modo da consentire il corretto interfacciamento co i parametri di un modello 3D. Vedi file allegato per maggiori informazioni.
Si aggiunge che non mi è nota la stringa identificante il Sistema Connesso (campo Connected System della Request) che, quindi, ho compilato a caso.
Grazie
Dale_Rosema
(To:RP_8326409)
There is no file attached as you mentioned.
Thanks but I can't find a function to attach the file.
I have attached the file to our thread
to edit table, you have to:
  • insert .tbl file into format or drawing
  • modify table in format or drawing
  • save modified table into .tbl file
Also, please read:
https://support.ptc.com/help/creo/creo_pma/r8.0/usascii/index.html#page/detail/About_Using_Tables_in_a_Format.html#
https://support.ptc.com/help/creo/creo_pma/r8.0/usascii/index.html#page/detail/About_Notes_in_Formats_and_Tables.html#
https://support.ptc.com/help/creo/creo_pma/r8.0/usascii/index.html#page/detail/To_Use_Parameters_in_Labels_in_a_Format_Table.html#
You can also go to youtube and search for creo how to make format
Martin Hanák
