Modifica file .TBL
Good evening.
I am using Creo Parametric - Release 3.0 (connected) Release 3.0 and DatecodeM150
I'm asking for support to understand how to modify a table in order to allow the correct interfacing with the parameters of a 3D model. See attached file for more information.
I don't know the string identifying the Connected System (Connected System field of the Request), so I have filled it in at random.
Translated with deepl.com
Translated by Corina Ionescu on Feb 23rd 2022
Buonasera.
Chiedo supporto per capire come modificare una tabella in modo da consentire il corretto interfacciamento co i parametri di un modello 3D. Vedi file allegato per maggiori informazioni.
Si aggiunge che non mi รจ nota la stringa identificante il Sistema Connesso (campo Connected System della Request) che, quindi, ho compilato a caso.
Grazie
