Good evening.
I am using Creo Parametric - Release 3.0 (connected) Release 3.0 and DatecodeM150
I'm asking for support to understand how to modify a table in order to allow the correct interfacing with the parameters of a 3D model. See attached file for more information.
I don't know the string identifying the Connected System (Connected System field of the Request), so I have filled it in at random.
Translated with deepl.com
Translated by Corina Ionescu on Feb 23rd 2022
Buonasera.
Chiedo supporto per capire come modificare una tabella in modo da consentire il corretto interfacciamento co i parametri di un modello 3D. Vedi file allegato per maggiori informazioni.
Si aggiunge che non mi è nota la stringa identificante il Sistema Connesso (campo Connected System della Request) che, quindi, ho compilato a caso.
Grazie
There is no file attached as you mentioned.
Thanks but I can't find a function to attach the file.
to edit table, you have to:
Also, please read:
You can also go to youtube and search for creo how to make format
