Modify a part removing cavity
aniccoli
2-Explorer
If I have a part with a cavity, is possibile using gui or using lisp to remove this cavity?
6 REPLIES 6
Can you give an example, or upload an existing model?
Creo Element\Direct Modeling 20.6.0.0.0
Here an example-
Part has a cavity. Part is obtained through unite parts inside assembly.
at the fast only a picture, in version 19.
Make it haf transparnt
Draw a frame araund the inner geo.
Move 3D
ignore Faults.
put it outside + confirm
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct Drafting, Modeling and Express 6-8-9 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
Thanks for your reply. I try to explain what I need..I need the external surface of a welded assembly that may have cavities within, for example, a frame obtained by means of tubular, if I use getvolprop lisp function on the part obtained as the union of the parts of the assembly, the surface of the inner cavities is considered . The surface that counts is the external one and not internal.The surface that will be subject to coating or heat treatment.
Hello Alesandro,
I see no other way.
Drag the internal shape out as described.
Make the calculation.
Thereafter, the inner mold with undo back to the old place
aniccoli
2-Explorer
(To:aniccoli)
Is possible get external surface using lisp?
Is possible write a macro that
1.Get external and internal surfaces using this command (oli::getres (get_vol_prop :for_part :part "/name_part" :area) )
2.Subtract from this value, area of internal faces , but how?
