ProE CREO 2 to ECAD import
sreddy-4
Hi ALL,
need help to make the EMN files.
While trying to export the PCB part file to EMN file its asking Co-Ordinate system, Bottom View  and Top View. But it is not taking Bottom and Top surfaces for the Part and its taking only Co-ordinate system.
Can anyone help me to solve the issue......
Thank you,
SaiKrishna Reddy
I am also facing this same issue.  SaiKrishna Reddy, did you figure out how to make the Bottom and Top View selections so that you could export an EMN file?
Anybody else know what to do here?
Saikrishna,
Can you please upload the model that you are trying to export to EMN?  I tried on a simple model and I was able to specify the TOP and BOTTOM, successfully.
Amt
I was having this same issue (as posted on November 2 to SaiKrishna).  For me, the issue was that the coordinate system in the part file was not on the pcb.  I created a coordinate system on the pcb surface and then had no issues saving the Creo part file as an EMN file, picking the new coordinate system, the bottom side, and the top side.
