Out of nowhere I am having an issue when trying to modify dimensions in the Sketcher. Typically, I was able to modify dimensions by double clicking and then making the change and moving to the next, but now I am unable to do that. When I double click the dimension will briefly highlight (like normal) then quickly closes before I can modify it. I have been forced to always use the Modify Dimensions wheel which I used to use occasionally when locking the scale for making changes to the sketch. Anyone experiencing this? IS there a fix? Any help would be greatly apprciated.
Steve
See this thread. https://community.ptc.com/t5/3D-Part-Assembly-Design/Cannot-edit-dimensions-in-sketcher-any-more/m-p/941436#M134193
It has something to do with the browser oddly enough.
Awesome, thank you so much for the quick response. It was driving me crazy.🤣
Please state the version/build (9.0.7.0 or 10.0.4.0) of Wildfire/Creo when asking a question. What may be 'broken' in one version release may be 'fixed' in another.
I did, but for some reason it didn't save it when i posted it. Thank you for the response and the issue has been resolved.
Looks like i also forgot to accept it as a solution, my bad
