Multi core processing for Manufacturing
RussellMcMahon
2-Explorer
I have a question, I'm using Creo manufacturing and I have a couple of surfacing toolpaths that take a very long time to produce CL data. I was asked, " doesn't Creo use multi threading"? I didnt know so I looked it up and it looks like the manufacturing side doesnt use multi threading. Is this true, how or where do I ask if this can be implement for Creo manufacturing to speed up CL data output.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&ved=0CB4QFjAA&url=http%3A%2F%2Fcommunities.ptc.com%2Fservlet%2FJiveServlet%2FpreviewBody%2F3254-102-1-3881%2FForm_2317156_Multi-threading.pdf&ei=ZVwcVL20OY23ogSz8YKwBg&usg=AFQjCNGAxENx9hd-NAtaYXI3MC7HXjlB1w
2 REPLIES 2
That would be a great improvement. As far as where to request it you can apply to be added to a technical commity here they hold online meetings with direct communications with the developers. I have not participated for a year so not sure how active they are now but worth a try.
Thank you, Im going to give it a try becasue I have a few other problems I would like to convey.
