Multiple radii with conic round option
VM_10376400
2-Explorer
I am using Creo Parametric Release 11.0 and Datecode11.0.0.0
Unable to add transitions or multiple radius values when using the D1 x D2 conic option.
Hi @VM_10376400
This is a known limitation of Creo Parametric. The behavior has been the same from early Creo Versions.
Hi @VM_10376400
Hi Mahesh, thank you for your response. Are there any known workarounds?
Hi @VM_10376400
There are no known workarounds as Conic D1xD2 is for constant round.
Thanks.
The only "workaround" is to create it yourself using datum curves and surfaces.
