Need a check in ModelCHECK
braj
Dear All,
I am using Modelcheck.i have two types of drawing formats. first type is used and checked in to PDM. Now, i got a ECN to change.
When i modify in the existing file i want to check-in with second type of drawing format mandatory  otherwise i don't want to allow inside PDM.
I need a check for this.
I tried format name check but it is not fulfilling my need.
Is there any solution in MC?
Bharath
3 REPLIES 3
CADQueen
(To:braj)
‌Do you have a parameter or is there maybe a system parameter you could use to identify which format is being used in the drawing? If you do you could set a condition to check that parameter on check in.
My book covers these kinds of things...
Re-Use Your CAD: The ModelCHECK Handbook
braj
(To:braj)
Dear all,
If anybody know the solution kindly let me know.
Bharath
llie
(To:braj)
Raj,
I would highly recommend purchasing The ModelCHECK Handbook. It is packed full of so much useful information that I have been trying to compile on my hard drives over the past 12 years. Most likely your company would pick up the expense and if they do not, then how much is your time worth?
Lance
