When I create a parametric wire chart for a harness, the length of the network is also popping up in the last row. The last row shows only the length of the network, nothing else.
How do I make sure this last row for network length doesn't show in my drawing.
Add a filter/by rule to the repeat region. Use !=NETWORK (not equals network). I use the following.
&harn.run.cond.name !=NETWORK
&harn.run.name !=NETWORK
jef
I'm sorry. But I couldn't find where I've to enter this relation. could you please guide me?
Table Tab / Repeat Region
Pick Filter / by rule
Enter relation (Use parameters driving the repeat region if the ones I listed are not the ones you are using. In the repeat region go to the top of the column driving the wire name, right click, properties)
Save and close
