Network route not displayed
cleamon
2-Explorer
After I create a network and complete the feature the network disappears.  It is still there but not displayed.  Is there some way to have it always be displayed?
lernst-2
(To:cleamon)
Hi Chris,
The network will display when you turn off the "Cable" icon.  Use the "Wire" icon.  If you want the wires to show, you would use the "Cable" icon.  See below...
Best regards,
Lori
3 REPLIES 3
fmohr
(To:cleamon)
Chris,
I could be a couple things.  1) Are you in displaying Thick Cables?  If, the network will disappear.  Go to Centerline mode to see the network.  2) Is there a "Network" or "Curves" layer that is turned off?  If so, unhide them.
I hope that helps.
Frank
cleamon
2-Explorer
(To:fmohr)
That was it.  Thanks guys
lernst-2
(To:cleamon)
Hi Chris,
Best regards,
Lori
