There are a bunch of OOTB check and update options available in ModelCHECK. However, they are not enough to address various demands. Here are the ones I collect so far. Are there any ones are required but they are not in the list?
Checks:
Updates:
Russell
Assembly cuts outside of the model - This has caused us a lot of performance issues and would be nice to warn or block these from happening. The automatic inclusion of components sometimes gets to be huge with complex assemblies.
Do we need similar check in Part mode?
Russell,
Is there an option to ignore certain layers; e.g. a layer starting with "_99"?
Also, has there been any discussion on matrix database?
Phil
Phil,
Which check is wildcard required? Start configuration option?
The approach for matrix database is still under discussion. It is not defined yet.
Russell
