New GD&T Profile Tolerance
Robert-Altman
7-Bedrock
[cid:image001.png@01CF4E79.95116BF0]
A new symbol, circle U, was added to profile tolerance. In the past, a design engineer wanting to specify an unequal profile tolerance on the drawing would draw a chain line in the applicable area. Two arrows were shown to displace the tolerance zone. In the new standard, the circle U symbol follows the toleranced value in the profile feature-control frame. This announces that an unequal tolerance is in effect.
Is there some way to add this to the interface?
[cid:image003.png@01CF4E83.87B03C70]
[cid:012445618@15012007-1FE4]
4 REPLIES 4
It's almost 5 years since ASME added the (U) symbol and almost 10 year since it was first proposed. If it's not there now...
Besides, the chain line is more direct.
x
A circle U is used in ASME, ASME Y14.41-2003 to be exact.It refers to the distance from the surface a profile tolerance is offset. A distance of 0.000 means that the tolerance is bilateral.This does away with having to draw a phantom line to denote which side a profile tolerance is applied to.
If its not a standard in the ProE drawing call out make a symbol
To: -
Subject: [proecad] - New GD&T Profile Tolerance
Date: Wed, 2 Apr 2014 18:57:10 +0000
A new symbol,
Robert Altman
Manager, CAD Engineering & Tech Support
You can turn this on in the drawing options.
ASME Y14.41
Circle U and other ASME Y14.41 settings
File-> Prepare-> Drawing Properties ->Detail Options
[cid:image004.jpg@01CF4E83.014CB3C0]
[cid:image005.png@01CF4E83.014CB3C0]
[cid:image001.png@01CE8938.2DDEC0B0]
Chad Smith
Product Engineer | Upper Extremity
www.acumed.net
Ahh, Creo or Creo 2
x
