New surface features are automatically hidden upon creation
hillmanwings
If I make an extruded surface, creo 7 automatically hides the geometry and greys out the feature in the tree.
To use the newly created feature, I first have to unhide it.  Same goes for sketched curves.
Does anyone know the config option to turn this off?
I created new part using to_part_solid_abs template created by PTC. I can see this result:
Suggestion: Check your template (you can zip it and upload it if you want me to check it).
Martin Hanák
John.Pryal
(To:hillmanwings)
Does your part have default layers set up? If so, chances are the PRT_ALL_SURFS layer is hidden so any new surfaces created will be added to this layer & therefore be automatically hidden. Check the layer tree to see if this is the case. There is definitely a config option for auto hiding sketched curves, autohide_external_sketch.
Good luck
John
