I got a problem with this. When there is an interference of two surfaces pro/e does not print the interference line. For example when a dowel pin is pressed into a hole on a surface. All you see is the round at the top of the dowel pin not the round where it meets the surface.
Is there a way to turn this on? like show tan lines or surface line or maybe setting annoying from yes to no.
I know where has to be a setting because some times it works.
