Non linear or linear setup in fastener simulation in creo?
ptc-2777300
As assigning fastener connections to the assembly, creo simulate creates contact surfaces in between two surfaces. My question is whether I should check the "Nonlinear/ Use load histories" box or not? For the contact analysis simulation, I always check the "Nonlinear" and then "Contact"?
0 REPLIES 0
