Note Underline Gap Issue
rbreyette-2
3-Newcomer
I am having a issue with notes that have a underline. I was running Creo 2 M030 and upgraded to Creo 2 M140 and the Gap from the text to the underline changed. M030 had a bigger gap from the text. M140 closed that gap and its very noticeable. When you are looking at a creo drawing it looks that same but I notice the problem when I export to PDF. see attached pics.
M030 has the gap I want but when I switched to M140 I dont get a gap anymore. Again I am using the same PDF export setttings.
Is this a upgrade improvement, a Detail Option setting issue, Config issue? I am lost here.
Thanks for the help in adavance.
-Ryan
Hi Ryan,
This seems to have been corrected in Creo Parametric 2.0, datcode M100 by SPR2194577.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS142917
Someone else must have complained the gap was too big and it got fixed. Probably an SPR from Pro/Engineer 17 finally clearing the queue.
Hi Ryan,
He says it's a problem in C2, M140.
