Number of Weld Feature
Mehmet_Ozdemir
6-Contributor
Hi All,
Can I see that how many weld feature I used?
Can I see this as a parameter on Creo?
Thanks for replies.
Check following video by Vladimir Palffy
https://youtu.be/0wRUtUTiqsQ
Let me know, If it helps you.
4 REPLIES 4
please ask also PTC Support.
Martin Hanák
Thanks for this video suggestion. It gave me clue about it. İt became so useful for me.
Actually my aim was doing weld cost calculation. And absolutely it ll help me.
Thanks again.
If you define WELD MATERIAL & WELD PROCESS it will be added advantage for you to do WELD TIME & COST Calculations.
https://www.youtube.com/watch?v=0YN38XdFCpE
https://www.youtube.com/@4kside/search?query=Weld
MdDesignAcademy #ptc #creotutorial #CreoParametric #design In this video tutorial we will learn about Define Weld Material, Process, Preferences & Fillet Welding in Welding of Applications tab of Creo Part Module. Follow the link to watch complete Creo Parametric tutorial's on: 1. Creo Sketch ...
