This is controlled by config option param_dec_places.
Instead of increasing this value set it to 4 andvalues will be shownin scientific notation, which might be a better solution.
/Bjarne
In Reply to Doug Schaefer:
WF4, M080
I'm going through an assy to make sure all the densities are assigned
properly to make sure I have an accurate weight. So, I've shown
MP_DENSITY *** a column in the model tree, however, it's only showing 6
places. My units are KG/mm^3, so I need 7 places for the density. For
example, aluminum is .0000027, but it shows as .000003.
If I open the part and check, it takes the 7 digit value, is there a way
to force it to display 7 digits in the model tree?
Doug Schaefer
