Hi everyone,
i want to "label" one of the parameters into my part. So far no problem using the text sketch tool and extrude feature. However, the text shows also all of its digits which means instead of "300" i get "300.000000", which makes it already impossible to get only one parameter labeled.
Is there a way to truncate the digits
MH
MH
you need to delete the existing parameter and create a new one of type "Integer".
no other way.
