Offset help?
Bifrost
7-Bedrock
Offset help?
Having problem figuring out how to make curved angle extrude, so the edge of extruded cuve stays let's say "paralel" to bottom. I added the picture to be more clear. English is not my primary language. Want to get maked edges from picture same distance from bottom.
Thank you.
Thank you for quick response.
Finded this tutorial. https://www.youtube.com/watch?v=Fb6gT_0UVoI . This is what I needed. Spend so much time , and it was this easy.... Thank you once more.
2 REPLIES 2
You will have to give up the planarity of the the connecting surface.
Try this; offset the lower curve to where you want it.  Now use boundary blend to connect it to the back edge.
This will show you what you are actually asking.
