Open Help by F1
Eike_Hauptmann
Open Help by F1
has one of you implemented custom help files for your tools.
At the moment we use a Button to open the help, but it would be nice to open it also by pressing key F1. But I didn't find a API that make this possible.
I could get it directly from keyboard, but thats not good because I can't check if my current dialog is the top dialog and problems with multiple threads and calls and so on. So I hope there is a solution directly from PTC TK / OTK API : )
Tank you and Br,
Eike
Be aware that the F1 key is already used for Creo Help by default.
