I have downloaded the student version of Creo Parametric 2.0 yesterday, and i have some questions about that.
I am a engineer student and i have to design some part on Creo Parametric at home. Computers at University use full version of Creo Parametric (Commercial Version), and I want to open my parts (designed at home with student version) on the commercial version at University.
Can someone help me? I don't know how to do that
Thanks for your help
Maxime,
There is a license for this called EDU_COM_Convert. This is discussed in the following document.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=101398
Hope this helps.
Maxime,
I am surprised, that your university uses Commercial licenses. Are you sure about it ?
Usually universities use Academic licenses. Files created in the session using Academic license can be opened in the session using Student license and vice versa.
Martin Hanak
Maxime,
Hope this helps.
