Open and solidworks file and embed childparts.
RH_10122575
Hi, I'm using Creo 11. I wish to know if it is possible to directly open a solidworks sldasm file and use the inseparable assembly/embed function so that I can keep all the data/childparts so that when I upload to windchill I only have the one assembly.
8 REPLIES 8
remy
(To:RH_10122575)
According to this article https://www.ptc.com/en/support/article/CS352914 it is supported.
RH_10122575
(To:remy)
Its says it is possible. But is not working. See process I follow and the issue where embed is greyed out.
remy
(To:RH_10122575)
right, so.
The SW import was successful and you need to embed some components (not all?) in an inseparable seembly.
In Data Exchange, you need to judge by the file so I recommend you get in touch with our Support Desk, file a case, attach your SW file, profile and template.
remy
(To:remy)
Had a look to this video from the brilliant Creo Parametric channel : https://www.youtube.com/watch?v=iOqBdz6gSVg
where is goes thourgh the process from Import to Embedding.
One notable thing is that Embed is available when Sub-components are selected.
Can you confirm this is what you select in your blurred out screenshot ?
RH_10122575
(To:remy)
yes components selected. i have made a basic file in solidworks still same issue. Could you try and see if same issue please.
remy
(To:RH_10122575)
Right.
I replicated the issue with Creo 11.0
the behavior is different than that off an assembly created in Creo from scratch.
File a case and if not me, our team will assist you.
RH_10122575
(To:remy)
Case 17809217
If you also have SolidWorks, I wouldn't even bother with Creo lol
