Opening a file in various versions
TuxedoCat
3-Visitor
hello!
can i work on creo 10.4 on one computer and then open the file to work on creo 10.1 and vice versa?
1 ACCEPTED SOLUTION
YES, you can work this way. But when you are working on big complicated project then it is better to use the same version on all computers.
Martin Hanák
4 REPLIES 4
tbraxton
(To:TuxedoCat)
Yes. All date codes of a version are compatible.
Involute Development, LLC
Consulting Engineers
Thank you!!!!
Martin Hanák
thank you for answering!!
