OverBraid functionality in Pro Cabling
MIke2
3-Newcomer
Does anyone know how the overbraid functionality works in cabling or what format it requires in a neutral/logical file? The only two help files i can find basically say it can only be created if the overbraid exists in a logical file. I was hoping it could represent the conduit in my harness assembly. Thanks, if any one can help.
2 REPLIES 2
gkoch
(To:MIke2)
Are you creating logical data with Creo Schematics?
I only remember that auto-routing of overbraid (multi-level bundle) is not routing the top level and you need to create the top level manually with Overbraid > Modify Overbraid:
CS121973 : After importing overbraid with multiple levels from Creo Schematics, the bundle to represent the top level is not routed
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS121973
MIke2
3-Newcomer
(To:gkoch)
No, We are actually using Autocad Electrical and creating our own neutral files. So at the minimum - i.m trying to find out what the format/parameters for overbraid should look like in a neutral file. the help files do specify that overbraid can only be created logically. Thanks.
