Isogen
ATEXT ,-241/-240
How do the modeling PCF file "end-Position-open" Does the record?
Although modeled using Blind Flange/Cap, "end-position-null" only generated
Does this mean, when you display the PCF as drawing (e.g. in I-Run), something is missing compared to the Creo model the PCF has been output from?
Or do you get an error when reading the PCF? Or an error when outputting?
No Error, No Display
Isogen ATEXT ,-241/-240 How do the modeling PCF file "end-Position-open" Does the record? Although modeled using Blind Flange/Cap, "end-position-null" only generated
