PDMLink Update
joe.kidd
PDMLink Update
Has anyone gone through a PDMLink build update? We are currently, and we have no access to our database for 2 days. That is how long our VAR is taking to do the upgrade from M050 to M060.
When they told me this I couldn't believe it. This is not a version upgrade, just a build update. All of our users had to export their workspaces to their hard drives and work locally for 2 days. The fun will be on Monday when everyone imports their data back in.
BTW, we had to do this in order for PDMLink to be supported with Creo Parametric.
Does anyone else out there find this unacceptable?
11 REPLIES 11
Joe,
We're just about ready to do the same thing, so your e-mail is
interesting,
We plan on doing 1 days testing on our development server and then 3 day
for the upgrade on the live server, there has been no mention of having to
export workspaces etc so I will check that out with them.
If you find any more "gotcha's" please let us know so I can prepare my
guys
Wonder how long an upgrade to 10 would take 😉
Best Regards
Chris Collinson
CAD Administrator
BenLoosli
(To:joe.kidd)
PTC has always recommened that ALL workspaces be cleared and deleted before any upgrade.
The workspace export would only be needed iF you do the upgrade during the week.
The upgrade to 10 is dependent on where you are coming from and going to. In my case Oracle based 9.0m050 to SQLServer 10m020 will require 3 steps and a rehost.
Remember that 10 is only supported on 64bit hardware.
first step is to get to 9.1m060 on Oracle.
second step is to convert to SQL Server.
third step is to upgrade to 10 and rehost.
Looking at 3 long weeends.
Ben
JMSCRA
(To:joe.kidd)
I am not particularly happy with 'another migration' if you will for what I think should be a reasonably easy update to go from 9.1 to 10.0. Sure the software is included in maintenance but our VAR wants ~ $25K for the effort to update us. It seems like we are getting the big green one. Had I known this was around the corner, we moved to 9.1 about 1 ½ years ago, I may have waited and skipped over 9.1 and moved straight to 10.0 or 10.1 even. For the small and medium businesses this cost is just about unbearable at times. I have factions yelling about SolidWorks and Inventor, both of which we do have in house unfortunately, and dollars like this just add fuel to their fire.
John M. Scranton
Manager Design Drafting
and Configuration Management
Ultra - USSI
4578 E. Park 30 Dr.
Columbia City, IN 46725-8869
*Voice: 260.248.3576
*Fax; 260.248.3509
[cid:image001.jpg@01CCCC49.38E14CB0]
Hi, John.
I am dealing with the same situation and we are paying about the same. Yeah, we just paid for maintenance. And I had to purchase a server too. I convinced the powers that be... by the UI is much nicer for the casual user, workgroup manager for Solidworks 2011/12 will work and the desktop integration for MS office is supposed to be better. Or at least on the demo it did. I don't think the upgrade is not difficult just time consuming.
Mike Pinkney
CAD Admin/Sr. Mech. Designer
Triple Ring Technologies
39655 Eureka Drive
Newark, CA. 94560-4806
Seriously? $25K? That's almost as much as our entire maintence cost.
Joe,
I did the M050 to M060 update myself on both a development system and our production systems and each were completed overnight in a matter of a few hours. We did not export workspaces or force workspace checkins and have not had any issues. (I had to do this in order to unexpectedly support a new version of Arbortext. As a result I also had to rollout a new build of ProE in the process.)
I'm not sure what your system looks like, but we have a WC server, a MSSQL db server, and a SAN and about 300 users. There are no load balancing servers and no replication sites.
We were trying to plan out our WC 10 upgrade when this update came up and derailed things. I am trying to accomplish the WC10 upgrade in-house, but we will likely use some outside help now that we are behind. The cost could be in the $29k range for cleanup, a development system upgrade, and a production system upgrade (about 1/5th of our maintenance cost).
John
harter
(To:joe.kidd)
I am shocked to read about the prices and difficulties you mentioned for the upgrade to 10. We will start this today and our consultance has said we will be able to do the upgrade from 9.1 in between two and four days. We´re already use virtual machines for the db-server and also for the application-server (normally) without any problems. So we again did not purchase physical servers. I will keep you posted about our experiences with the upgrade process. But I can tell that we have to pay about 5000€ and no not more.
Rainer
Rainer Harter
Fraunhofer-Institut für Physikalische Messtechnik IPM, VID/Systemadministration und IT-Sicherheit
www.ipm.fraunhofer.de
kkrofft
2-Explorer
(To:joe.kidd)
Tristar just did this for our Intralink installation. 1 Day for the main
system and one for the replica.
Completed over a VPN during our holiday shutdown.
Kory Krofft
CAD Administrator
Trimble Navigation Ltd.
5475 Kellenburger Rd.
Dayton, Oh 45424
Ph. 937.245.5356
That is completely unacceptable. I updated PDMLink from M030 to M060 plus updated 3 replica servers all in a day and a half. I did this over a weekend and systems was back online well before the users came back to work the following Monday. As you said, it's just an MOR update and not a full blown upgrade.
Alexius C. Chukwuka
IT Analyst, Global SAP Basis
Technical Change Management (TCM)
Deere & Company World Headquarters
400 19th St, Moline, IL 61265
Office: (309) 765-3133
Mobile: (319) 429-5336
OK, so we do have a replicated server in New Zealand, but it still took them 4 days to complete this, including Sat & Sun.
Warning to those who are not aware, the .wf file for Creo gets loaded to the same spot as the Wildfire .wf. If you need to go back to WF you will need to segragate the .wf folder.
I added this line to my startup script. Set PTC_WF_ROOT=C:\PTC\Creo_work\.wf
Good point. In addition to splitting out ROOT and CACHE, I now set a
different ROOT for each version of ProE/Creo...
