Has anyone gone through a PDMLink build update? We are currently, and we have no access to our database for 2 days. That is how long our VAR is taking to do the upgrade from M050 to M060.
When they told me this I couldn't believe it. This is not a version upgrade, just a build update. All of our users had to export their workspaces to their hard drives and work locally for 2 days. The fun will be on Monday when everyone imports their data back in.
BTW, we had to do this in order for PDMLink to be supported with Creo Parametric.
Does anyone else out there find this unacceptable?
Seriously? $25K? That's almost as much as our entire maintence cost.
OK, so we do have a replicated server in New Zealand, but it still took them 4 days to complete this, including Sat & Sun.
Warning to those who are not aware, the .wf file for Creo gets loaded to the same spot as the Wildfire .wf. If you need to go back to WF you will need to segragate the .wf folder.
I added this line to my startup script. Set PTC_WF_ROOT=C:\PTC\Creo_work\.wf
