I just recently upgraded from Wildfire 4.0 to Creo 2.0. In my previous drawings I used the "&pdmrev" and "&pdmrev:d" scripts to show the rev info. However this does not appear to be working in Creo 2.0. Is something wrong or did PTC eliminate this script in Creo? Is there a new/alternate script that I should use instead? Thank you in advance.
-Karl
Did you also upgrade to Windchill/PDMlink?
When we ugraded from Wildfire 4.0 to Creo 2.0, we also upgraded from Windchill 9.1 to 10.2
Set the hidden config.pro option "dm_emulate_ilink_sys_parameters" to "yes".
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS51632
Or, if legacy data isn't a concern you can switch to using the native Windchill parameters on your drawings.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS24526
Just be careful, some don't work in Creo:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS18803
Hi Karl,
Did Tom's suggestion resolve the issue?
We are using team center unified. Does PDMREV work with team center unified using CREO 2.0? How can the version of the drawing be printed on the pdf file to control our release process?
This is a different question, please start your own topic 🙂
