PTC product for steel frame building design??
ptc-6774025
I am not a PTC user but have seen a friend design a wheelchair and perform FEA to determine its performance under load in order to choose the best material selection.
I fabricate small steel frame builings and would like to know if there is PTC application that could be used to analyse their design to determinine if they would meet code for loading, wind force and so on.
huggre
(To:ptc-6774025)
Roger
You should check out the "Creo Advanced Framework Extention" and "Creo Simulate" packages from PTC and evaluate if these packages has the functionality you are looking for.
Im sure a sales rep. from PTC would be more than happy to answer your questions.
