PVZ file does not respect my simplified rep
JR_10738612
2-Explorer
Hello, everybody:
I am trying to generate a PVZ file using simplified reps to only show a part of a bigger assembly. In the Annotate tab of CREO I have the correct components on display but when I export the file to CREO view I get extra components that should be hidden. Any idea of why this happens and how I could fix this? I have attached photos of the CAD view and the PVZ output below.
Thanks in advanced for the help 🙂
maybe https://www.ptc.com/en/support/article/CS47882 article will help you.
Martin Hanák
llie
(To:JR_10738612)
Save a copy of the export_pvs.rcp file to C:\Temp\creoview, This file is located in the Creo loadpoint\Common Files\<Datecode>\text\prodview. Make the changes needed and then add the following to your config.pro
intf_pv_recipe_dir C:\Temp\creoview
