Parameter Syntax for assembly note
rrich
2-Explorer
I am looking for the proper syntax to put at the end of my parameter call out in the note that will pull the parameter value from a specific part or assembly.
Example in my note
&PARTNUMBER(syntax here)
should pull the part number parameter from a sub assembly of my choosing. I thought it should look something like this but it did not work.
&PARTNUMBER:a1
any help would be appreciated.
Ron
1 REPLY 1
TomU
(To:rrich)
You need the session id for the sub assembly you are trying to read. So if the session id of the sub assembly is 3, you would put &PARTNUMBER:3
Tom U.
