I am trying to figure out if there is a way to store a value/parameter for component/sub-assembly at a top assembly that will not need to be stored in the part or sub-assembly? Feature name works close to what I want but I don't want to use feature name because we use that for other things. Also I can't have to components with the same feature name.
Any help would be very much appreciated and thanks in advance!
How would the component/sub-assembly use this parameter? What about when the component/sub-assembly is opened without the upper level assembly in session?
Isn't that a component parameter in assemblies?
I thought about that too, but I think the component value for sub-assembly components would be stored at the sub-assembly level, not at the top assembly level.
I wonder if notebook functionality (previously called layout) with "declare" would be useful. Of course then you're actually modifying all the lower level components/sub-assemblies.
I tried the component parameter and it does require storing the parameter in the sub-assembly. So it would work great at the assembly level just can't go into the sub-assemblies.
If I understood the problem correctly that you may want to take a look at flexible components. This way you can have a parameter value in the assembly context and a different value when the part is opened by itself.
The parameter need to exist in the part but it's value is independent from the assembly.
Keep in mind that as the number of flexible components goes up, Creo performance goes down. A hidden family table gets created for each item that has flexibility defined.
I had thought about flexible components as well, but I can't add the parameter to the parts. That is revise the part to add the new parameter.
