I have a question about datum curves from an equation. The equation involves Zernike polynomials which will change the curve based on angle. Basically I need to input a curve every X degrees around the same origin 360 degrees. I'm currently inputting each curve one at a time on individual CSYS rotated X degrees and changing the angle to match the CSYS by hand.
Any better way to accomplish this task?
Ideally I would like this to be parametric so I can change the increments to more or less than X degrees so I don’t have to touch each datum curve.
Any tips would be greatly appreciated,
Doug
