Part Colors
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Part Colors
- Labels:
2D Drawing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
"Chris DiSalvatore" wrote:
Where is the command to change the part color?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Autodesk ® Expert Elite
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
"Chris Benner" wrote:
Seth, or any other PTC person, why did PTC not include a "Command Locator" in WF5? When going to the ribbon UI so many commands have been completely relocated or renamed that many users are having one #@$&!! of a time finding things they have used for years. Inventor 2010 has also just changed to the ribbon UI, and on the opening screen, prominently located in the middle of the ribbon is "Command Locator", which lists all of the common commands, and presents (when mouse is rolled over) a graphic showing where on the ribbon or toolbar to find this command. Pretty nice.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Ahhh yes, the hated ribbon. I'm staying on WF4 until either the ribbon goes away, or I'm forced to use it by management. I. HATE. IT.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
In case anyone is still trying to figure out how to change the color of the part, here's how. With the part model open, click on the Appearance Manager icon, which looks like a grey ball in about the middle of the toolbar. Then pick the color you want to change the model to. Then go over to the model tree and click on the model name, then "OK" in the dialog box. Alternatively, you can click on surfaces with the paintbrush cursor that comes up if you don't want to change the entire part color. This also works in assemblies.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I have tried to change surfaces in assembly mode, for instance assembly cuts of *stamps* so they stand out from the parent material, but in WF5 it won't allow it. It will change the entire part or not at all. I know that in WF3 and earlier it was possible, but it looks like the capability was removed in WF5.
