I have a Pause glyph/Symbol for a Copy Geometry feature inside a Part File. ![]()
I know about the Pause glyph in assembly file where it means its constraints are frozen, but no idea about the part modelling. ![]()
Tried redefining the feature, keeping parent part in session and in the same working directory. ![]()
But if I create any new copy geometry features then there is no pause symbol. ![]()
Please help. ![]()
Using Creo 2.0 M090
Hi Guru,
I did some searching in our internal TS database and found that older cases that were created regarding the same issue, required the part to be sent in for R&D to fix the error.
If you have maintenance, I would suggest creating a Tech Support case for this issue. You can create a case here - Case Logger.
Unfortunately, there isn't a straight forward resolution to this issue.
Amit
Hi Amit,
Sorry i am checking in after a long time. Thank you very much for the reply.
I will create a case for this.
Guru
