Personal experience with Circular references
mhucik
I would like to ask you PTC Creo or ProEngineer users something about your personal experience with circular references. i know how to find out CR (crc file, reference viewer) how to remove it. i know it could give some regeration problems, but what kind of problems? In which part of desing proces it could be problem?
3 REPLIES 3
mhucik
(To:mhucik)
Why is it a problem, if you have CR?
dm-3
(To:mhucik)
StephenW
(To:mhucik)
Circular references causes additional regeneration time, in my opinion, that seems to be one of the primary problems.  Many circular references in an assembly can seriously degrade Creo performance.
I have seen one case where upon regeneration, a circular reference would change a part and then the next regeneration, it would change it again. I believe that specific one was a relation was causing a value change with each regeneration. I have only experienced that one time.
