Photorender - WF2
JWayman
Photorender - WF2
Good morning,
I have used Photorender in WF2 in the past and ended up with one or two
renders that were just about acceptable. This morning, I came to use it
again and I am unable to see any detail in the room. The room walls are
visible, the right shape and size, but they are just grey. I have tried
loading rooms from the graphic library and others from a tutorial I found on
the net, but they remain grey. If I load the Appearance menu (the one with
the little coloured balls), I can change the colour of each wall. I cannot,
however, figure out how to get the room to look like the 'room with a view'
or 'graduated sunset' rooms that I have seen before.
What am I doing wrong this time?
0 REPLIES 0
