Play path - CL file in use
hillmanwings
Hi, I have noticed a problem thats been in Creo/pro/e for a long time, maybe someone knows how to ifx it?
When I use the 'play path' option, and select a CL file to play, Creo holds on to that CL file until I quit Creo altogether.  This means I can't use an external post processor, delete or rename the CL file if I have used 'play path' with that file.
Erasing everything from session doesn't help, I have to quit creo to be able to do anything with that CL file again.
Does anyone else experience this?
Justin
I tried the same and it work without any problem. Play Path > Selected a Cl file > Open > Done, this started CL display and once this was completed Creo was free for further use. It it is not working as expected, try contacting PTC support.
hillmanwings
(To:Mahesh_Sharma)
Hi KSM, did you also try to post-process the CL file after playing?  This is my issue, the actual CL file is 'in use' by Creo until I quit.
Justin
