Point Driven Pattern Adds Instances
dgschaefer
Creo 3, M070
I have a sketch made up entirely of 4 geometry points
I then created two other sketches, both almost exclusively tied to the first of the four points in the original sketch:
I then group those two sketches and create a pattern of the group driven by the points in the original sketch.
Creo creates 5 pattern instances instead of 4, one being slightly off of the original.  There's an extra set slightly offset from the original and not aligned to any of the points:
Anyone ever see this?  I can selectively disable the extra instance that doesn't align to any of the 4 points, but at some point I assume Creo is going to try to remove the wrong instance and screw up the children of my pattern.
How do I fix it?
LinkedIn
OK, I also noticed that only the original is properly aligned to the points.  Argh.
So, I redefined the pattern, clicked the "Options" tab and clicked "Use alternate origin" and selected the same point that both sketches were built from:
Now there are only 4 instances and they are properly aligned.  I don't know why it would have worked wrong the first time, but this fixed it.
LinkedIn
2 REPLIES 2
LinkedIn
Thank you, this helped me out with a similar situation.  Now to get to the bottom of why it adds instances in the first place...
