During assembly renaming I'm wondering is it possible to have :
BOX_A1_1.PRT in to BOX_A1.PRT
just using template box to avoid doing this one by one part.
I have STEP assembly file which I would like to use with new part names.
Im offline PDM and working on Creo 2.
Try to take a Save a copy of assembly
Refer document: https://community.ptc.com/t5/3D-Part-Assembly-Design/Save-a-copy-document-for-rename/td-p/446965
I am not sure what you are trying to accomplish, but I'm guessing it is:
BOX_A1_1.PRT --> BOX_A1.PRT
PLATE_A1_1.PRT --> PLATE_A1.PRT
SOME_NAME_1.PRT --> SOME_NAME.PRT
if that's the case, then you could Use Template: *_1.PRT = *.PRT
Hi Paul,
What I am trying to accomplish is to have file names without underscore line or any other sufix thay may appear when I open STEP file of assembly.
The STEP file which I have is probably (or 100%) saved from Creo assembly in .asm extension.
It starting to be interesting when I try to do this renaming job with assembly which count over 500 parts and of course with several "reuse" items
So far I didnt know for this "Save copy" solution with "txt" importation from Excel which has been posted by lokesh lokesh.
And of course, I do not need to add any comment about editing in Excel which is one very powerful software tool
