Pre placement of view in drawing
ptc-1972305
Dear all, I create drawing and put different view so instead of putting manually I want to add three views(Elevation, Plan and side view) automatically when I create new drawing. Is it possible in proe by playing in config.? Thanks, Vimlesh
If you are creating a new drawing, then you could use a template drawing. That would be a drawing with pre-defined views and other items you want each time. If you have an existing drawing, then I don't know of a way to automatically add those other views.
