Principal Axes Rotation Angles
gpommeranz
I have a mass system that I am designing isolators for.  I'm attempting to create a new coordinate system that represents the principal axes so that I can use that to identify locations and angles for the isolators.  My problem is that when I compute the principal axes, then create a new coordinate system at the location and orientation of the reported principal axes, the location is correct but the rotation is slightly askew and I can't figure out why.  In the picture below, I would expect my 1, 2, 3 axes and X, Y, Z to be on top of each other.  I uploaded the CAD files as well.
tbraxton
22-Sapphire I
(To:gpommeranz)
Have you reviewed this document yet? If not check out the process needed to get you to the target.
Article - CS33398 - After having entered 3 values in >Orientation >Selected CSYS axes for rotation about X,Y and Z when creating a CSYS1 from another CSYS0, orientation of CSYS1 seems wrong in Creo Parametric.
Involute Development, LLC
Consulting Engineers
7 REPLIES 7
StephenW
(To:gpommeranz)
I have had trouble when translating and rotating coord sys in one csys. I will break it up in to translation for a 1st csys and a 2nd csys for rotation.
Not sure if this will help you or not.
Thanks, I tried that but still  got the same results with the axes slightly askew.
tbraxton
22-Sapphire I
(To:gpommeranz)
That did it!  Thank you very much!  Rotating about a newly created axis makes a big difference of how the coordinate system ends up.
I meant to accept your answer as correct and accidentally clicked on mine.
tbraxton
22-Sapphire I
(To:gpommeranz)
No problem, if you notify the moderators they can make the change.
Already sent.  Thanks again!
