Pro-Cabling (WF 2): Minimum Bend Radius
ptc-882204
Is there a way to calculate the bend radius of a bundle/wire/cable in Pro/E WF2. Looks like ProE calculates it internally and compares to min_bend_radius parameter and says that the min bend radius is violated. The min_bend_radius is also kind of strange in bundles. The parameter changes when the wire are added to the bundle. what is this calculation that its based on? Will be appreciative of any answers
1 REPLY 1
The calculation is based on the real diameter of the bundle. After you add a wire into the bundle, the bundle diameter gets bigger.
