Not sure if this is the right forum, but hopefully someone here knows the answer.
In Pro Diagram, is there a way to reset the wire count?
When you delete wires and start adding them again, it does not rest itself.
Lets say you routed wire1, wire2, wire4 and wire5, then you delete wire5.
Then you start routing again, the count resumes at wire6 not with wire5.
Hopefully this makes sense.
